Eventide and the pedals….
Home › Forums › Products › Rackmount › Eventide and the pedals….
Viewing 8 reply threads
    • #107533
      bazsa82
        Eclipse Input Mode: Mono 1.
        Two effect in one preset FXA and FXB.
        Can I use the pedal, witch to subordinate only FXA?
        Where I can select to use in a Preset? Pedal 1 or Pedal 2?
      • #121346
          bazsa82:
          Sorry, don't understand. Must be the season of the witch.
          bazsa82:
          Assuming you mean "how do I use these in a preset", look at the User manual See p.45 on setting up "External Controllers", then p.40 on modulating parameters.
          The manual is a little unclear on this complex topic, but p.40-46 is the right area.
        • #121347
          bazsa82
            So.
            I would like choose pedal 1 to FXA and pedal 2 to FXB. It's possible?
            Now when use the pedal 1 with FXA and FXB the pedal to affect the both effect: FXA and FXB.
          • #132502
              Sorry – still don't understand. Can you try and explain more fully and clearly what you are trying to do ? Give examples with specific presets and parameters.
            • #132518
              bazsa82
                Sorry my English not too good, but I try it.
                So,
                Mono 1
                FXA Dual Wammy (preset 157) + FXB Diatonic 2 (preset 163) = user preset
                Pedal 1 – I plug a sustain  pedal.
                I would like if the pedal 1 subordinate only FXA.
                Where can I set in FXA and FXB witch pedal to affect?
                Because now the pedal 1(sustain pedal) affect FXA and FXB at same time.
              • #132524
                  I think I get it. The two halves of the preset (FXA and FXB) are both controlled by the same pedal, and you want to control them separately
                  What you will have to do is look at the parameters and find which parameter is externally controlled then change it. In this case, it will be easier to change FXB. So, do the following:
                  1) [PARAMETER], then <EDIT FXB>, then (MASTERS).
                  2) You will see that SEND has a line under it. This tells you that this parameter is modulated, in this case by 'ext1", the pedal. Let us change this.
                  3) Press and hold SEND, until you see <MODULATE>. Then hit <MODULATE>. This will bring up the normal controller screen, showing "ext1" as the source. Turn the wheel to select another source.
                  4)  Then hit PROGRAM to exit and save it.
                  That should be it. I would suggest that you use another ext as the new source, or "off" if you want no external control to FXB. See pages 40-46 in the UM for information on modulation and controllers.
                • #132528
                  bazsa82
                    Thanks so much I do it well!! This effect is amizing products and You are a Gentlemany!!!
                    I have got only one question:
                    So, when I use preset 157(dual wammy) alone with the pedal, the effect change when I rocked the pedal. When I used this preset with 163 (diatonic) and I adjusted the correct pedal settings in the wammy's setting, it doesn't functioned well, because It ring or don't ring – It on or off – It functioned or not.
                    I tried all source settings.
                    I hope you are understand me.
                    Thanks,
                    Best Regards!
                    Bazsa82
                  • #132545
                      bazsa82:
                      How did you adjust these settings – is it possible that that is the problem ?
                    • #132553
                      bazsa82
                        I copied the factory preset (wammy) and it functioned well. Thanks!!!
