Eventide Eclipse V 4.01 Sometimes doesnt’ Power On
Home › Forums › Products › Rackmount › Eventide Eclipse V 4.01 Sometimes doesnt’ Power On
    • #115235
      Hi guys!
      My Eclipse V 4.01 has a strange behaviour respecting to power on.
      Sometimes the unit just don’t power on.
      Pressing the Power on Switch, a small click is heard inside the unit, but nothing happens.
      This only happen sometimes, and it looks completely random.
      Anybody helps?
      Thank You
      Best Regards,
      Paulo
    • #151487
        I'm afraid this could be many things. The fact that you say it happens only sometimes suggests a loose connection or a bad solder joint. Something in the display circuitry is most likely.
        In time it will most likely get either better or worse. You can probably hurry this up by vibrating or bumping the unit.
        You will probably have to send it in. Sorry. If it is still under warranty, do this soon.
        If you bought it used, talk to your vendor.
