Hi Everyone,
I’m having the strangest issue with my Eclipse V4.01
It is losing the input signal after anything up to about 45 minutes. the problem ceases after I adjust the input level for the loss of signal by as little as 0.1dB.
I’ve also noticed that one channel will usually lose input first, if I do not adjust the input level & leave the unit for a time (there doesn’t seem to be a specific amount of time) then the other channel will lose input too…….bizarre.
I have a done reset on the unit and I’ve also re-installed the OS both of which have not resolved the issue.
Has anyone had this problem and more importantly know how to fix it?
Many thanks in advance
Neville
