Eventide/GCX Setup Questions
Home Forums Products Rackmount Eventide/GCX Setup Questions
    • #105655
      Since I am using Channel A and Channel B of the Eventide into loop 1 and 2 of the GCX, I am setting each of my patches to DUALMONO. I am not sure how I should set the input mode however, I am assuming since I am using both Channel A and Channel B that Stereo would be correct since I am sending this signal thru to a DUALMONO configuration each time. I also assume that if only one effect block is used everything willl still work properly with this setup?
    • #117520
       Yes, use STEREO input.
