eventide h9000r dsp unoccupied
Home › Forums › Products › Rackmount › eventide h9000r dsp unoccupied
Viewing 5 reply threads
    • #177892
      Roman Sandor
        Hi, I have been using the H9000r for 5 years. Now with DSP 3 it says dsp unoccupied??? I can’t use all 4 engines. Only 3 work. What should I do to make all 4 work again???? Yesterday I worked on the H9000r and everything was ok. I turned it on today and only 3 are working. Anyone have any experience??? I flashed the firmware but it didn’t help. Thanks for any help.
      • #177894
        wvought
          I keep my H9000R in a “machine room”, which in my case is just a fancy term for a closet with sliding doors. These doors block the sound of the fan, which is why I keep the H9000R in there.
          But the closet can tend to be a bit damp, and on one occasion only two of the DSPs were seen by the device. So I looked inside and popped the DSPs out, only to find that the “missing” DSPs had mold growing on the contacts. I cleaned them off with some spray contact cleaner and a rag, and wah-lah…problem solved.
          Now I’m careful to not always keeps the closet doors completely closed, thus letting the air circulate, and the problem has not returned.
        • #177895
            Sorry for the issues you are having. The first step is to try the USB self-test and send us the results. Please follow the instructions below, and send the results to support@eventide.com. We can help you troubleshoot further there.
            https://cdn.eventideaudio.com/manuals/h9000/2.0/content/appendix/startup_seq.html#usb-self-test-mode
          • #177896
            Roman Sandor
              <span style=”vertical-align: inherit;”><span style=”vertical-align: inherit;”>Děkuji, zítra udělám autotest USB a pošlu zprávu.</span></span>
            • #177897
              Roman Sandor
                Hello, I am sending the self test of my H9000r in the attachment. I performed it according to the instructions. I will wait for your diagnosis. Thanks
              • #177908
                  Sorry, I do not see any attachments. The forum is not the best for this kind of thing.
                  Please email support@eventide.com and we can troubleshoot the issue further there.
