Eventide Newbie needs Help with TimeFactor…
Home › Forums › Products › Stompboxes › Eventide Newbie needs Help with TimeFactor…
Viewing 3 reply threads
    • #107348
      Hi all.
      Yesterday i got a TimeFactor in a trade. Im new to all this Eventide world, and to be sincere i couldnt get the TimeFactor to give me the dry signal of my guitar in the whole hour i spent tweaking knobs. All i could hear was the wet signal, despite of me tweaking the Dry/Wet knob and every other knob on the board. When the pedal is on bypass there is absolutely NO signal at all. I powered it using a universal adapter. I dont know what to do. Can anyone help me? PLEASE. Thanks in advance.
    • #120912
        Many possibilities:
        1) The unit could be faulty. Beg borrow or steal another one, and see if it does the same thing.
        2) There may be a problem caused by not using the correct power supply. We STRONGLY recommend that you do not use unapproved power supplies. But, to be fair, a power supply problem is more likely to affect the wet signal, not the dry one.
        3) Most likely – you may have some kind of cabling issue – try different cables, making sure that they are mono type (tip and sleeve, no ring).
        If all else fails, contact support@eventide.com, especially if the unit is less than one year old.
      • #120915
        caveman
          killdry setting?
        • #120916
            Mr caveman is of course correct – this could be it.
            If you have just received the unit, I would recommend that you return it to factory defaults as described in the User Manual. This will deal with many possibly incorrect settings.
