Home › Forums › Products › Stompboxes › Eventide Pitchfactor Harpeggiator Sound Problems?
June 26, 2010 at 11:21 am #107146
bo1989
MemberHey Guys!
I've got a problem…!
In my band we're using the Eventide Pitchfactor Harpeggiator Sound in almost every song and it is in fact influenzing our sound a lot!
The Problem:
I would start with bank 1 preset 1 which would be a HARPEGGIATOR preset then switch to preset 2 which would be any other preset and then switch back to preset 1 in bank 1 but then there is no regular starting point from where the harpeggiator starts!
So each time I press Bank 1 Preset 1 which is the harpeggiator pattern I programmed for the song, it starts at a different point of the pattern and that ofcourse is a serious problem because the whole song get's out of tempo and everybody gets really confused!:D
Is there a possibility of getting rid of this problem!?
Greetings!
June 28, 2010 at 10:03 pm #120545
achaput
ModeratorWhen using Harpeggiator In PLAY Mode, pressing the Flex Footswitch will restart the arpeggios.
July 18, 2010 at 9:58 pm #120599
ParticipantIn that live scenario described above, you're effectively mixing Bank and Play mode functions. [Preset change + restart of the Harpeggiator sequences]. That's a possibility with a connected Aux Switch. For a single routing, it doesn't have to be a 3-way switch. Even a keyboard sustain pedal will work. Momentary switches work best; a latching switch will require two presses to 'cycle back'.
- Press the encoder + right footswitch to enter the System mode. Turn the encoder to AUX SW.
- Press the encoder again, and turn to FLX > TIP (for example). A routing of FS2 > TIP would also work correctly in Bank mode.
- Use the left / right footswitches to change the destination / source under encoder control (< -or- >).
- Press the encoder + right footswitch to exit the System mode.
The problem with this approach is that you'll have to hit two switches simultaneously to change the preset and restart the sequence. MIDI has other solutions. Your live band may not depend on sync to MIDI clock. A direct solution would be to use a MIDI pedalboard.
Some 'boards (Behringer FCB-1010; Roland FC-300) are capable of sending out both Program Changes and CC values when each footswitch is pressed. The Program Change will select your preset, and a Continuous Controller value (bound to FLX in the System menu) will reset the sequence, at the same time.
