Eventide router utility conflicts with IAC Driver
Home › Forums › Products › Rackmount › Eventide router utility conflicts with IAC Driver
    • #108390
      galaxiesmerge
        When I turn on the Mac OSX (Snow Leopard 10.6) IAC Driver with Eventide H8000FW Version 5.5 the H8000FW router stops communicating (i.e. it goes offline).
        Is this normal behavior?  Once I have sent my routing to the Eventide I don't think I need the router to continue communications but I wanted to verify this with you.
      • #123109
          Since IAC is a MIDI device, it points to some software issue on the Mac which is beyond our knowledge. Sorry.
          But, on the bright side, I can confirm that you don't need the routing utility to communicate with the H8000 during normal use. Probably best to save any routings you think you will need on the H8000 and then they will be directly accessible.
