Home › Forums › Products › Stompboxes › Eventide SPACE – Can I go from preset #1 to #50, #60… fast?
January 27, 2012 at 4:05 pm #108362pedrotalaricoMember
Hey guys,
I play some songs live that requires me to jump across presets like crazy on my Eventide Space stompbox.
There's any faster way to jump between distant presets (#1 to #50, for example)?
Thank you for the help,
Pedro.
January 27, 2012 at 5:36 pm #123082anxiousmofoParticipant
You'll need to buy a foot-switchable MIDI controller for that, methinks.
January 27, 2012 at 5:49 pm #123083brockParticipant
The fastest method is MIDI Program Changes (usually sent from an external MIDI pedal or foot controller). As an alternative, you can move the order of the presets around to match the sequence in your stage set. Then Bank Up using the onboard footswitch, or Bank Down using an auxiliary switch.
September 30, 2017 at 12:07 am #147291wilkinsiParticipant
You want a MIDI pedalboard.
September 30, 2017 at 7:25 pm #147297wilkinsiParticipant
I use my Line 6 Helix to switch presets on my H9. I can either increment/decrement and load or jump straight to my favorite presets, or both.
October 7, 2017 at 11:07 pm #147368greatorexandiParticipant
Thank you both, appreciate the suggestions.
Hi Brock,
I see that this is an old thread, but would you be able to recommend a particular option for the first solution you suggested?
Thanks in advance.
Thanks in advance.
Literally ANY midi switcher would do.
If you need something small, I reccomend the Disaster area designs DMC-3XL. Its the size of a regular stompbox.. but pretty flexible midi-wise.
