Home › Forums › Products › Stompboxes › Eventide Space goes Crazy
February 15, 2013 at 6:59 pm #109596thetipicoMember
I'm very worried because in one year and a half my Eventide Space has turned crazy, it doesn't work. It's simply that the screen goes crazy and it doesn't start. I attach a video so you can see the problem. What can I do? Since I don't know how does the warranty of your products work in Spain.
Video Link: https://www.dropbox.com/s/t6h91a2d7mxtmql/Eventide-iPhone.m4v
Thank you
PD: The USB port is also inoperative and I can not update to a previous version of the firmware.
February 15, 2013 at 11:00 pm #124295
Make sure you are using the Eventide Power Supply – my guess is that the power supply is bad.
If the Power Supply is OK, try "restore factory system settings." If this fails, you should go to your dealer, or support@eventide.com.
You will find Warranty Information at the back of the User Manual.
February 19, 2013 at 3:14 pm #124303robertthompsonMember
I'm having exactly the same problem with mine and have found references to the same issue on other forums. This sounds like a real problem with an expensive pedal.
February 23, 2013 at 12:01 pm #124316thetipicoMember
Solved!
The original Eventide AC/DC Adapter failed. I replaced with a generic adapter and it works correctly.
what a relief!
Thank you for your attention
R.
February 23, 2013 at 6:46 pm #124317thetipicoMember
The new adapter I bought recently to replace the original one has just got damaged. I have a question: the original Eventide adapter says it's 9V – 500 mA (the same that the one I've bought to replace it), on the other hand, in the Space input connection it says 9V – 1200 mA. Can you help me with this?
Thank you so much!
February 23, 2013 at 9:28 pm #135250
Everyone complained about our big (1200mA) power supplies, so we introduced a smaller one. Unfortunately, some of these are not as good as the bigger ones. Anyone who thinks they have a bad one should contact support@eventide.com.
The pedals need about 500mA at startup, and about 350mA thereafter, so a supply rated at 500mA should be OK.
Note that the usual warranty warnings apply. You can get official Eventide supplies from the Eventide Web Shop.
