Eventide Space one side louder
Home Forums Products Stompboxes Eventide Space one side louder
Viewing 12 reply threads
    • #116356
      Hey
      I have the problem when i connect a synth to the pedal via unbalanced or balanced cables that one side is louder.
      when i go with mono out to mono in on pedal and stereo out, is no problem, only with true stereo.
      change line/guitar or line/amp does not help
      my routing is: Synth to Space to Rme fireface 800.
      i had the problem with right side louder or left side louder when i change the cables.
      hope anybody can fix this with me
      cheers
    • #157194
      joecozzi
        Does this only happen when the pedal is connected to the RME? The problem may be with the gain setting on the RME inputs. I don’t know if you can adjust that via software or something. On the pedals, there is no way to individually adjust the level of each side.
      • #157196
        only the mono in and outs on the space gives the synth sound out, reverb comes from boths sides.
        for understanding,when i play a piano from a vst than i hear the piano on one side with reverb and on the other side only reverb without piano but when i change the input or output on the space,then it changes the sides.
      • #157197
        or when i put only mono in on space and stereo out on space than its perfect, but not true stereo. i have stereo synths, i need true stereo
      • #157198
        joecozzi
          Check to make sure that the pedal is in ”Normal” routing mode and not “Pre/Post” or “Wet/dry” in the System Settings.
        • #157199
          i checked it, an its on normal mode
        • #157200
          tsternfeld
            If you bypass the Space, is one side still louder?  If you set it to use the relay bypass mode?
          • #157201
            In bypass mode its the same, only without reverb and bypass mode is on normal and relay changed it not, always same.
          • #157202
            joecozzi
              From this sentence, it seems like this problem happens when you connect to the Space in stereo (L/R output of synth to L/R input of Space). Is it possible that the output levels of your synth are not set to unity gain for some reason? Maybe one of the outputs is louder than the other?
            • #157203
              No, i checked it with vst synths in ableton and with a hardware synth, same problem, only mono to stereo works perfect. In rme is no channel louder, all set on 0db and ableton the same.
            • #157204
              tsternfeld
                When you activate relay bypass on your Space, the pedal is entirely out of the electrical circuit.  If, when you're relay bypassed, the signal level is still mismatched between the channels, the problem is with your synth or your cables.
              • #157205
                Ok, i check it after work with other inputs and outs on the rme, and i check how the timefactor works with true stereo. Thanks a lot, i write tomorrow about the results
              • #157208
                heey iam so sorry. i solved the problem. it was 2 bad cables who make this : )
                buut thank you very much for this nice and fast support : )
                love for eventide <3
              • #157195
                thanks for answer, the rme settings are correct, i checked it.
