Eventide Space – scrolling presets with a MIDI controller
Home Forums Products Stompboxes Eventide Space – scrolling presets with a MIDI controller
Viewing 3 reply threads
    • #111411
      andros77
      I am very happy with my SPACE but one of the issues it's represented by its playability live.
      I like to save my presets one next to the other so I can move from one to the other. In a live situation, I would need to do this quickly and therefore I purchased an external midi controller which allows me to change presets in play mode. The only thing is that it is slow! it takes those 0,seconds which become AGES in a live situation. I am not reporting here the brand of the controller, unless you request me to do so.
      So my question is, is there a way to make the scrolling process quicker? by updating the sowtware for example? and, does it depend on the controller or on the eventide space? If there's a midi controller (or aux switch) which allows me to scroll the presets qucker, I'd like to know which one it is
      thank you and advance for your response!!
      Andrea
    • #125460
      Don't really understand what you are saying.
      You should be using MIDI Program Change, which does not have any scrolling issues, or requirements on where you put your presets.
    • #125461
      andros77
      hello
      sorry for my bad English. By "scrolling" I mean moving from one preset to the other, going from preset 1 to preset 100. It is possible to do so in play mode with a MIDI controller, but it seems to take a lot of time, i.e. there is a little bit of latency between presets, approx. 0,5 seconds.
    • #136227
      Preset loading is not instantaneous – these are large and complex algorithms – that's why they sound so good.
      But, again, normally you would load them as needed with MIDI Program Change, rather than stepping through them, in which case a  fraction of a second would not be a problem.
