Existing presets for MIDI access
Home Forums Products Stompboxes Existing presets for MIDI access
    • #105831
      pd_cdn
      I setting up a ModFactor and TimeFactor as part of a MIDI looper/footcontroller setup. I'm trying to find out the preset list for the canned presets. For example if the standard preset is Bank 5 Number 1 does that map to preset 009? Thanks for your help.
    • #117855
       You can set up a MIDI map to get whatever relationship you want. Or use the default settings. See under [RCV MAP] in the Manual.
