Experience with TapeEcho ???
Home Forums Products Stompboxes Experience with TapeEcho ???
    • #163071
      juandascanio
      It’s just my setup or TapeEcho mode doesn’t cut any bass??? (even with filter on 100!)
      Can’t put the feedback over 40 o so, otherwise the delayed sounds are way too muddy
    • #163117
      The filter in Tape Echo is a high cut filter, so at 100 you will be cutting a lot of high frequency from your signal.
      Have you tried a low filter setting, or 0? This should allow you to use high feedback settings without the delayed signal sounding muddy.
    • #163164
      Bodde
      Yes it is only a high cut filter. No low cut. I find a low cut filter on delays more useful in general than a high cut. For the same reason you mention. The repeats will get muddy. With a low cut your repeats will not muddy the overall mix so much.
