expression pedal help
Home Forums Products Rackmount expression pedal help
    • #107020
      grpaul2002
      HiGuys
      Just started to go through MF and TF algos, fantastic!!
      My expression pedal has been calibrated and is working fine with original presets etc
      If i refer to the preset descriptions, especially the time factor, it mentions toe and heel down modifies the sound on the majority of the new presets, nothing is happening when i move either way, as i stated it works with the original presets.
      Do i need to program, or are they programed and i have not set up correctly
      your vast experience is appreciated
      cheers
      Paul
    • #120271
      IDeangelis
      Hi Paul
      from the Presets Manual, page 90:
      "These are large and sophisticated algorithms which can have a noticeable loading time. An expression
      pedal or other modulation source connected to External 3 is pre-wired to many of the parameters"
      Have you followed this guideline?
      I
    • #120273
      grpaul2002
      I
      thanks mate, i have the expression pedal plugin pedal 1 on rear, just was not sure using ext3, for it to work on the old presets it must be defaulting to another ext.
      i will have a play
      cheers
      Paul
