Expression pedal range change since new firmware?
Home Forums Products Stompboxes Expression pedal range change since new firmware?
Viewing 4 reply threads
    • #105722
      Something weird has happened since I've updated the firmware on the TF to 2.03[2].
      I'm using an M-Audio expression pedal.  I used to have my pedal vary mix from 0 to 100.  Now, none of the ranges will go to 100.  The pedal has a range adjustment on the side but that only seems to shift the range up or down.  e.g., 65 to 100 or 0 to 87.  I'm no longer getting the full range from 0 to 100.
      There's a worse problem with this change: since the Timefactor isn't seeing the range as 0 and 100 simultaneously, I can no longer set the expression pedal at all.  My old settings are still there but I can't adjust them or add new ones.
      Am I doing something wrong?  or…..is this an unreported bug in the new firmware?
         Lance
    • #117666
      achaput
        Have you tried plugging the expression pedal in before powering up your TimeFactor?
      • #117670
        Actually, the TF and pedal are all mounted to a pedalboard.  It's always plugged in.
         Realistically, the biggest problem is not being able to adjust the pedal any more.  I could live with the range being shifted…..but at this point, the expression pedal function is really broken since it's stuck where I left on each patch before the update.
      • #128803
        achaput
          Which model of expression pedal is it? Is there a fine-tune control on the expression pedal? If so it should be turned all the way down.
          Alan
        • #128805
          Aha!  Well…..it's fixed.  What's strange is I used to have the fine tune knob set to the minimum.  Now I have it cranked all up….restarted the pedal and it worked.
           As long as it's fixed – I'm happy!
          Thanks Alan!
