October 22, 2010 at 4:58 pm #107340edoMember
I've read on the algorhythm description that it's possible to control the q-wah as a "real" wahwah with an expression pedal connected to the external in… however, i would like to know if it's possible to control it with an expression pedal connected directly on a rocktron all access, as i use it to control some other parameters from other units and wouldn't want to add another exp pedal to my pedalboard…. Any suggestions?
Cheers
October 22, 2010 at 5:14 pm #120887
On Eclipse, all external control is done through one of the "ext" virtual devices. Find out which one of these is the relevant one (Algorithm Manual says that it's either ext3 or ext4 ), and change it to use the MIDI CC from the Rocktron (see User Manual if necessary).
October 22, 2010 at 5:51 pm #120890edoMember
thanks for your reply. I tried that, but it's not working, it works more like an upside down volume pedal, in the sense that toe down = no sound, heel down = full sound. What am i doing wrong??
October 22, 2010 at 6:07 pm #132091
You will have to tell me what you did ….
October 22, 2010 at 6:12 pm #132092edoMember
i assigned cn 17 to ext4 and exppdl on the modulation shape. When I rock the pedal, the xnob parameter goes from 36 to 0, as opposed from 0 to 99 or so i guess…
October 22, 2010 at 6:21 pm #132093
A little too cryptic for me, I'm afraid.
But, either way, the Eclipse offers many ways to adjust the EXT settings – play with these and it will do what you want. Assuming you have V4, set TYPE to min/.max, and adjust the MINIMUM and MAXIMUM values appropriately (p.42 of UM).
November 2, 2010 at 10:27 pm #132126Robert TiffinMember
I am also haveing trouble with the Factor presets!The conections to externals all seem to be conected to external 3.Nothing to external 4 as mentioned in the alg. manual.So pedal 3 will modulate all conected parameters.Even shape?it does produce interesting stutering but is this correct and the way you intended it?
When switching shape to external pedal the algorithm freezes and I do not understand where or what this external pedal is!
I am also wondering how to get a reverse wha or reverse filter effect from algorithms in the Eclipse? is there a positve/negative polarity switch somewhere?[idont think so] or a trick with seting up the slope or angle on the filters in Q-wha, Filters or Mod Filters algorithms?or maybe the mod block?
November 2, 2010 at 10:38 pm #132127
Robert Tiffin:
All the externals are connected to Ext3, with the exception that those where a pedal is used as a source as opposed to controlling a parameter are connected to Ext4. There are only a few of these.
Robert Tiffin:
This is an example of one where the pedal is a source and needto be connected to Ext4.
Hopefully one of our Eclipse users can answer your wah question better than can I.
November 2, 2010 at 11:03 pm #132128Robert TiffinMember
Yes thankyou however I find no modulation hapening from ext 4 when the "shape" hot key parameter is set to external pedal?
could you forward that reverse filter question to Italo or somebody there who could answer..Is it possible in Eclipse?..thankyou.
