EXT “led blinking and cannot lock?
Home Forums Products Rackmount EXT “led blinking and cannot lock?
    • #112383
      vaultstudio
      I updated unit but I have blinking EXT led and setup screen conveys all unlocked….Source is INT ….?
    • #127595
      If the Ext light is blinking, it means that a routed source is unlocked, even if you are not using it. If this concerns you, go through the routing screens and unroute anything you are not using.
      If the source is INT, it is likely that all digital sources will be unlocked – you need a sync source for a digital input to lock. This can be the digital input itself, or a central sync such as wordclock.
    • #138436
      vaultstudio
      All good after 5.6 update…..Big Smile
