External Control of “Bypass Mode” in Time Factor Pedal…
Home Forums Products Stompboxes External Control of “Bypass Mode” in Time Factor Pedal…
Viewing 3 reply threads
    • #107139
      Hi there!
      Quick Question:
      Can you switch between "Bypass Modes" with external devices? Like Aux Footswitches or Midi switches.
      At least toogle between DSP+DLY and just DSP.
      It would be great to save it with Presets too!!!
      JB
    • #120520
        ZenBlues:
        Not really
        ZenBlues:
        Sorry – these are global settings, so cannot be saved with a preset.
      • #120525
        Too sad to hear that… would be a great function!!!
        Other idea. As I understand in BYP+DLY mode the delay will keep sounding after I hit the bypass switch form on to off right? But what if instead of that I switch from preset A to B, and preset B is a Blank (no delay set) preset? Would that do the effect of sudden stop?
        I think that could work. Unless the "spill over" function works between presents change too?
        Thanks for your help guys!
        J
      • #131733
          I assume you are using TF. This has a feature called SPILLOVER, which if set, will preserve the delay "tails" from the previous preset. Note that these tails are now going part of a different effect, so may change in sound.
