Factor Lib Problem (cant Load)
Home Forums Products Stompboxes Factor Lib Problem (cant Load)
Viewing 9 reply threads
    • #107185
      eilly
      Im running OSX 10.6.4.
      I can install and open Factor Lib fine but I cant get it to load from My TF. I checked to make sure the midi clock out was off and it is.  My computer is def seeing the TF and works with the updater and SysEx Librarian 2 programs. Factor lib just keeps saying LOADING and nothing comes up
      An sugestions? I have tried USB and Midi with no results and have not seen any post that seemed to help with ideas.
      thanks
    • #120615
      Hard to know from here. Can you see the TF in MIDI/config ?
    • #120616
      eilly
      yes, should i run midi only not usb?
    • #131775
      USB is fine – with TF that carries MIDI as well.
    • #131776
      eilly
      I can see the time factor under the Factor lib prefs
    • #131777
      Does it show as both Input and Output ?
    • #131778
      eilly
      yes
    • #131785
      In that case, I'm out of ideas. Sorry. Try another computer ?
    • #120635
      brianm
      I had the same issue running FactorLIb (with TimeFactor) in Windows 7 – the presets seem to load, but the program doesn't end.  It worked fine in Windows XP.
      It also worked in Windows 7 with a third party SysEx program called MIDI-OX.  This allows you to initiate the dump from the system menu of the XFactor, where you can select exactly what it is you want to dump – in this case, ALL is probably safest.  I haven't tried restoring presets from MIDI-OX, but it should work…
      I see it is based on Qt libraries – is there a Linux version?
    • #120644
      There are some issues with Win7 -these will be fixed in the next release later this year. Sorry.
      No Linux version at this time due to miniscule demand and miniscule available time.
