Factor Lib Tutorial?
Home Forums Products Stompboxes Factor Lib Tutorial?
Viewing 5 reply threads
    • #107639
      alexworkman
      Is there any place where there is a tutorial for the factor lib software? And is it possible to edit the setting on my MacBook. I am just a little confused with the interaction between the software and my TimeFactor. Thanks for you help!
    • #121569
      There is a User Manual PDF . It's a fairly simple piece of software.
      Not sure what you mean by "edit the setting in my Macbook." To which setting do you refer ?
      In the first version, which will be the one you have, there is not much interaction. Essentially FactorLib will do the following:
      1) get presets from the TF (File/Open from MIDI)
      2) allow you to save them on the computer (File/Save)
      3) send presets from the computer to your TF (MIDI/Send)
      4) allow you to mix presets from different save configurations.
    • #121570
      alexworkman
      I didn't know if there was a say to create presets and send them to the TF from my computer.
    • #132775
      Currently you can only load and save presets to/from the computer. They have to be created on the TF.
      The next version will allow some editing.
    • #132792
      markschick
      Seems like someone told me that FactorLib didn't work with V3 Timefactor software. is this true?
    • #132795
      Yup. There is a bug caused by the fact that it was written well before V3 was planned.
      It will be fixed in the next release, due shortly.
