Factor Pedal registration coupons?
Home Forums Products Stompboxes Factor Pedal registration coupons?
Viewing 5 reply threads
    • #112058
      makers
      Sorry if this has been answered before. I registered two Factor Pedals thought the control app and received a message saying I would get H9 algorithm coupons.
      Where do those show up? I can't see them anywhere or figure out how to redeem them. Thanks!
    • #126923
      gkellum
      If you have one or more of your Factor pedals connected at the same time as an H9 and you go into the store in H9 Control, you should see the number of coupons available in the status bar at the top of the screen, and when you press the buy button, it will give you the option of paying with a coupon.  You have to have your Factor pedals connected to use the coupons, so if you only connect one for example, you will only see its two coupons when you go into the store and not the two coupons from your other Factor pedal.
    • #126927
      marcusm750
      Hi, gkellum.  So the coupons are tied to specific Factor pedals.  Makes sense.  But the coupons can be used for any and all algorithms, correct?  For example, I can use the two PitchFactor coupons to buy Blackhole and rotary.  Or only for algorithms from the Factor whose coupons I'm redeeming?
      Do these coupons ever expire?  I don't have an H9 now but expect to get one in the near future.  Also, what if I sell one or more of my Factors (not that I would actually do so) after the coupons have been used?  Do the algorithms purchased with the associated coupons disappear?  I would expect the new owner(s) to register the Factors so it would be known in your licensing scheme that I don't own them anymore.
    • #137563
      gkellum
      marcusm750:
      Yes, coupons can be used for any and all algorithms.
      marcusm750:
      The coupons never expire, and the algorithms bought with a coupon don't disappear if you sell your Factor pedals.  The coupons associated with a Factor pedal can only be used once, and if you sell your Factor pedal and have used its coupons already, then the new owner won't be able to use them. If you don't use the coupons, then they'll be useable by the new owner after he registers the pedal.
    • #137566
      marcusm750
      Thanks for your quick response, gkellum.
      Ah, yes, makes sense the coupons are one-time only, either by me or the next/previous owner(s), and your licensing would know this by the serial number(s).  No worries, my four Factors will be with me for a very, very long time.  🙂
    • #143738
      Scottmcconnachie
      Is this still the case for owners of factor pedals plus a h9?
      • #143743
        gkellum
        Yes, this is still the case.
      • #143745
        Given To Fly
        It worked! You basically just handed me $80. Thank you!
