fast changing presets???
Home Forums Products Rackmount fast changing presets???
Viewing 4 reply threads
    • #105254
      hi!
      one question: how fast can the eclipse change presets? i?ve once owned one and wasn?t able to play it live, because i?ve used it as the only fx-unit and 100% wet and with every preset-changing the sound totally disappeared for some seconds – so for me as a guitarplayer i couldn?t use that for live-playing…but now i read on some folders "ultra fast program changes"…??? did they improve this or what…???
      thanks a lot,
      rudi
    • #116764
       Rudi
      the unit is faster than before.
      Using MIDI in a smart way you may not even need to change preset. If the preset does your typical chorus/delay/verb, CCs can turn fx on and off and change parameters values. So you won't need to change the preset unless it's a total different sound the one you need next.
      I
    • #116778
      Does the new upgrade mean faster preset changes?
    • #127843
      The 3.5b is definitely faster than the 3.1 in changing presets. Like the tech guy said though be aware of things that don't work correctly at this point.
      I'm still trying to learn this unit so I can't really be of much help there but it was faster in loading the presets without question.
       good luck
    • #127844
      hi and thanks a lot! which are the things that don?t work correctly at this point?
      thanks,
      rudi
