Quick question, RE: the modulation algorithms. Is the “predetermined factor” between Fast and Slow 1/4X? That is, for example, a “fast” Speed at 4.00 Hz. = Slow 4.00 Hz. = 1.00 Hz.? Or the reverse: Set a latched Slow Speed to 16.0 Hz. as the equivalent of a ‘normal’ Speed of 4.00 Hz? And does the same apply across all of the Modulation algorithms (where appropriate)?
My ears tell me that’s an accurate assessment. I never actually tested out that theorum side-by-side until this morning. While I don’t believe that has changed since the ModFactor / H9 implementations, I’ve been under the wrong impression for years.
I could’ve sworn that I read 8:1 or 10:1 ratios somewhere in the distant past. I came by this need for absolute sync accuracy while creating a specific Program with EXP pedal mappings. Thanks in advance.
