Feature request – metering “presets”
Home Forums Products Rackmount Feature request – metering “presets”
    • #178377
      ColinMuir
        Hi, could “ADAT in 1-8”, “Analog out 1-8” , etc be added to the dropdown menu when selecting metering?
        This would automatically assign all eight meters rather than have to do them one at a time.
        Sometimes I want to quickly switch from metering different groups of i/o.
      • #178380
          In Emote, you can select Window > Meter Bridge and this will allow you to view groups of 8 meters at a time in the application UI. These selections will also populate the meters that are displayed on the front panel. https://cdn.eventideaudio.com/manuals/h9000/2.0/content/emote/overview.html#menu-bar
          I’m not sure if we’d be able to implement something on the front panel that changes all meters at once. If you’d like to use the front panel for this, you can change them one at a time as this currently works fine.
