Home › Forums › Products › Stompboxes › FEATURE REQUEST: Swap stuff, randomizer / blender
- This topic has 7 replies, 3 voices, and was last updated 2 years, 2 months ago by brockstar.
November 22, 2022 at 12:21 pm #166942brockstarParticipant
There’s no quick knob 1 “swap” option under the routing section on the H90 control, is that something that may come later? I hope!
Also what about a randomizer for parameters, and a blender option (like boss sy-300) that allows you to blend different programs / presets
I wish “swap” was a feature that could be mapped to a hotswitch or aux switch or expression pedal! It’s cool to go back and forth!
November 22, 2022 at 12:30 pm #166948brockParticipant
Click on Quick Knob 1.
I don’t know about mapping something like this. I notice that it ‘breaks’ Performance Controls assignments with a swap. As it should. Performance targets are mapped to Preset A or B, and those parameters don’t necessarily apply to the ‘swapped’ algorithm.
November 22, 2022 at 1:48 pm #166959coirbidh_99Participant
If you simply swapped the internal routing order, rather than actually switching the presets between the A and B locations, that would keep the performance controls the same, though it contradicts the UI paradigm and might create problems if you’re using an insert.
November 22, 2022 at 12:31 pm #166951brockstarParticipant
“Click on Quick Knob 1.”
I know, it’s available on hardware but not on control app.
November 22, 2022 at 2:51 pm #166966brockstarParticipant
Another thing that could be cool at least for the H90 control app is a MORPH feature, which I doubt could work on hardware screen like the H90
I loved using it on the EssenceFM synth. I think it could be cool to have on the app at least!
Here’s me showing it off for the fm synth. https://www.instagram.com/p/CRop78oAYOl/
November 22, 2022 at 5:25 pm #166972brockstarParticipant
I also really do wish the freeze option could do a TC ELECTONICS infinite sample sustainer or Ehx SuperEgo / SuperEgo Plus “infinite mode” where each time you hit a note or chord it stacks on top of each other over and over and when done just double tap switch to turn off.
November 22, 2022 at 6:05 pm #166975brockstarParticipant
Maybe another cool thing, similar to the swap thing I said… but I wish “series or parallel” was a feature that could be mapped to a hotswitch or aux switch or expression pedal too! Could be cool to go back and forth in a tune!
