Feature Suggestions Band Delay / Factory
Home Forums Products Plug-Ins Feature Suggestions Band Delay / Factory
    • #105242
      Posted by surroundsfx
      Just a couple of (small) suggestions for Band Delay and Factory:
      – add a “glide” control to the function generator’s S/H modes to smoothe the changes
      – add a “glide” control to Band Delay to make frequency changes via MIDI “portamento-ish”
      – add MIDI note## as modulation source, mapping note#000 to the min value and #127 to the max value…this would allow “playing” the pitch-shifters in the factory
      – add MIDI note-on status (“if a key is pressed, set value to ON else to OFF”) as modulation source, for triggering the function generator or similar
      – add a note mode to Band Delay that keeps the relative settings of the 8 voices, but transposes the whole lot via MIDI; note#64 should be the neutral value.
      – make it possible to map the snapshots to a midi control that will then sequentially interpolate between them (only makes sense for Band Delay). Routings /switches should change state on arriving at their repestive snapshot.
      – add an ADSR (or AR if DSP is an issue) to each voice of the Band Delay
      Cheers,
      Denis
    • #117459
      DGillespie
        Hi Denis,
        We'll add these suggestions to the feature request list and we'll see if we can get to them.
        Thanks for your input.
        Dan
