Home › Forums › Products › Stompboxes › Filter/EQ Sweep using h9 and expression pedal?
- This topic has 3 replies, 1 voice, and was last updated 8 months, 1 week ago by polsmall.
November 4, 2019 at 1:17 pm #115595sstrohbehnParticipant
Hi All:
I’m hoping to either find a preset or build one myself that would assign an EQ frequency amount to my expression pedal so I could use the pedal to do an EQ sweep left and right across the spectrum band. I’m hoping to accomplish a live filter sweep similar to the feel of the synths swelling/sweeping in “Somebody Told Me” by the killers at 0:05-0:20 (https://www.youtube.com/watch?v=Y5fBdpreJiU). Would like to be able to use this either on my guitar and/or my synths.
Does anyone know of a preset that has this setup, or if not which algorhythm I should use to do this? I tried making my own building off the EQ Compressor algorhythm but it seems the filter bands are hardlocked into certain frequency ranges, meaning I can’t assign an expression pedal/hotknob to sweep across the entire spectrum. I also found it difficult to get the hotknob to be tied to the expression pedal by default in the patch ( I was able to successfully assign the frequency 1 and frequency 2 settings to the hotknob and move them in tandem, but that doesn’t create as dramatic effect as a single EQ point being dragged across the spectrum left and right).
Any links or guidance would be most appreciated.
Thank you,
November 4, 2019 at 2:51 pm #153112brockParticipant
I haven’t looked into your example, or any wah-type algorithm options.
You might find the Resonator or Sculpt examples below useful:
https://www.eventideaudio.com/community/forum/stompboxes/resonator-otherworldly-wah-filter-sweeps
https://www.eventideaudio.com/community/forum/stompboxes/sculpting-some-spectral-panning-fx
November 4, 2019 at 6:36 pm #153116sstrohbehnParticipant
Thanks. I’m quite surprised in this day of edm this is so tricky to find/do. This is video shows how the effect is done in ableton.
Can the same sweep be setup in h9 with the expression pedal putting a single frequency parameter up and down in frequency and simultaneously up and down in gain.
June 1, 2024 at 7:55 am #183012polsmallParticipant
I’ve the same issue, did you find any solution ?
Thanks,
