Firewire 16 channels
Home Forums Products Rackmount Firewire 16 channels
Viewing 7 reply threads
    • #106941
      teddy
      Hi everybody,
      I don't understand when the H8000 manual said that in firewire there are 16 channels. Because the main input are limited to 8 channels.
      Can someone can explain this, because if i can use 16 channels and not 8 in firewire when the signal go out from logic to the H8000 and return to 16 channels input it will be very very very good.
      excuse for my french english Smile
    • #120121
      You are correct that the main inputs/ outputs are limited to 8 channels.
      The FireWire in/out can also be routed to ADAT and AES11-18, giving a total of 24 sources/destinations. You do not have to use them all.
    • #120124
      teddy
      thanks.
      It 's interesting, but a little bit complicated. Geeked
      Is it possible to plug in firewire my H8000 to my computer, have 16 output from my daw to my H8000 , do the processing for the 16 input, and get the result of the 16 outputs ?
      Also, are they yet presets and routing presets that uses this standard configuration ? Because I don't see this in the preset manual.
    • #131291
      teddy:
      No – you can only process 8 channels from FireWire – you are limited by the number of main inputs and main outputs. The H8000 is essentially an 8 channel machine with 2 engines, rather than a 16 channel machine. Sorry.
      teddy:
      Again no, because this is NOT a standard configuration. Note that routing presets are described in the User Manual, not the Presets Manual.
    • #131292
      teddy
      thanks.
      Is it possible to say to eventide developpers to upgrade the H8000 kernel (i like this word, in french it is a very exciting word) to 16 channels ? A little bit of C++….
      it's a joke Big Smile
    • #131293
      It's the hardware – those guys have no sense of humour.
    • #132734
      pgiaccone
      Hi, I've another question: how many parallel effects can the Eventide H8000FW deploy in 8 channels of input?
      i.e.: is the hardware capable to run 8 parallel mono compressors or 4 parallel stereo reverbs?
      Thank you,
      Piero
    • #132737
      This depends on the size of the effects and the sample rate. At 48kHz, you can run one of (for example) the following 8 channel presets on each of the two DSPs:
      3    23    Octal Compressor
      3    16    Compressor_8
      3    31    8*10 Grafic Eq
      3    12    8 Diatonicshifts
      6    20    Combdelays 8ch
      6    27    LongPanningDelays8
      10  32    4 Stereo Verbs
      These are just a few of many – you get the picture …
