firewire issue H8000FW
Home Forums Products Rackmount firewire issue H8000FW
Viewing 4 reply threads
    • #105907
      xnix
        Hi Italo,
        I have been trying to configure my h8000fw via firewire with a Lucid 88192 using Eventide Dice software with Cubase SX3 in PC (over firewire).
        I have attached the Lucid via db25.
        I am trying to create a simple configuration with the Lucid travelling over one firewire set, and DSP A over 1-4, and DSP B over 5-8 of the other firewire set for DAW effects.
        My probelm is I am not getting signal over firewire 1 line in.
        I have tried the Lucid over firewire 1 with DSPs over firewire 2, as well as the reverse with the same problem.
        What should I do?
        Is it likely a software issue in the computer, or a software issue in the H8000?
        Or could it be harware?
        Thanks
        Troy
      • #117992
        Hi Troy
        very unclear what you have been trying to do.
        Is the Lucid an AES-EBU interface? the DB25 is an AES-EBU interface and has nothing to do with the FW interface.
        In addition to this, any question regarding audio routing should include a *very detailed* description of the H8000 internal ROUTING.
        Thanks
        I
      • #117993
        xnix
          Yes the Lucid is an AES-EBU interface.
          I am routing 8 channels of analog in/out from the Lucid into the H8000FW to connect to the DAW over firewire directly (bypassing DSPs). – Firewire1
          I am routing 8 channels inside the DAW to the H8000FW over firewire as well (4 to DSPA, 4 to DSP B) – Firewire2
          It is difficult to describe it further without a block diagram, but I started with the ADAT & AES8 I/O setting and modified it. I am not using ADAT at all and just want access to the two DSPs seperately from the DAW.
        • #129138
          Sorry
          I don't understand what you are trying to do.
          best
          I
        • #129139
          xnix
            I have sent you a diagram.
