Firmware problem H90
Home Forums Products Stompboxes Firmware problem H90
Viewing 5 reply threads
    • #185894
      danperfect
        Hi
        I tried to install the latest Beta, but it failed – I used both Control 1.7.11, and the new control beta 1.8.6.
        Using 1.7.11 I get the error File ‘XC-09236’ file size error, using 1.8.6 I get a ‘405’ error.
        Thinking the firmware might have been corrupted (unit working fine), I put it in recovery mode, and I cannot re-install any – even older – version of the firmware.
        What should I try now?
        Thanks, Dan
      • #185896
        danperfect
          Actually, further to this I have just connected another unit, and I have the same problem and error message with it too, so doesn’t sound like corrupted firmware on the unit..
        • #185897
          danperfect
            H90 Control Version: 1.8.6 – Mac OSX 14.7
            Log started: 30 Oct 2024 12:43:10pm
            Initiated firmware update to version: 1.9.4
            ‼️ [H90InstallThread.cpp:220].run > Download of ‘h90-1.9.4.os’ failed with status: 405
            Initiated firmware update to version: 1.8.6
            ‼️ [H90InstallThread.cpp:220].run > Download of ‘h90-1.8.6.os’ failed with status: 405
          • #185898
            danperfect
              Ok, I’m guessing it’s your end – I have tried 2 different computers, 2 separate H90’s, multiple USB leads. I can’t restore or update.. Is there a service side error?
            • #185899
                Sorry for the issues you are having and thanks for reporting this.
                We’ve just fixed the issue on our end so please try updating again and let us know if that works.
              • #185902
                danperfect
                  No problem, all sorted now, thanks!
