Firmware Uploads are failing
Home › Forums › Products › Stompboxes › Firmware Uploads are failing
Viewing 13 reply threads
    • #184815
      peteycorn
        Hi
        Just bought the Riptide.  Awesome pedal, simple to use.  Tried to connect to EDM (which I’ve been through with my Blackhole pedal) can’t wait to try the crazy presets that people have made wondering what they came up with and all I get are the first 5 –  I should mention that I had to switch my usb connection from the hub to the back of my Mac Mini quad core i7 running Catalina (says it’s good enough) and now I’m seeing my new pedal right away, still only 5 presets, go to upgrade firmware = nope (spinning wheel)  – – so now I think –  shit I didn’t register it yet, so I go register it and have to restart my machine to get EDM to see Riptide, but it sees it now, so I let the spinning ball spin for hours this time (just in case that it was doing something!)
        I come back for find that it has timed out do to lack of communication (jeez that stung) lol *jk 🙂 but I digress
        Is it the pedal?
        System Requirements – Check
        USB Cable works – Check
        Plugged directly into Mac (no hub) – Check
        Using Eventide Power Supply – Check
        Registered Pedal – Check
        What am I missing?  Should I return it to Guitar Center and wait for another won ( I can ) but I’d rather just figure out what I’m doing wrong to keep getting the spinning wheel instead of messages going through the firmware update process (like in the youtubes)
        plz help
        thank you much
      • #184826
          Sorry for the issues you are having.
          To clarify, only 5 presets can be accessed on the pedal itself, but when you use MIDI or connect to EDM, you should see the additional presets without needing to update. What happens when you power on the pedal and connect to EDM without attempting to update? Do you only see 5 presets?
        • #184840
          peteycorn
            I only see 5 presets when I open EDM.
            It says 2 firmware updates available, but they are useless (in this instance)
          • #184863
              Thanks for the information. Can you please try using the pedal in update mode and trying again? Power on the pedal while holding the Vibe footswitch and LED button, and then use EDM to attempt the update again.
            • #184867
              peteycorn
                EDM doesn’t see the Riptide when I powered up the Riptide in update mode (top and bottom preset lights flashing)
              • #184874
                  Sorry to hear you are still having issues. Are you able to try installing EDM on a different computer and attempting the update again?
                • #184876
                  peteycorn
                    No.  And I know that EDM works on my computer because I also own your Blackhole pedal.  I think we’ve tried all that we can try, and that maybe I should return the Riptide to Guitar Center, and have them replace it with a different one (that hopefully works)
                  • #184882
                      Just to make sure, when you connect your Blackhole to EDM are you able to update the firmware on that pedal with no issues? Can you try disabling any antivirus programs you may be running and seeing if that makes the Riptide update work?
                    • #184884
                      peteycorn
                        I hooked the Blackhole up with EDM and it was working perfectly.  I did NOT attempt to update the firmware. The firmware was already up to date. I took the Riptide to Guitar Center – Sherman Oaks and returned the defective one, and ordered the replacement.  Hopefully that one will come fully operational.  I’m optimistic and wouId be very surprised if I got two bad ones in a row! Thanks for trying to come up with a fix for the first one
                        • #184918
                            Hi peteycorn, please let us know if the replacement Riptide is working correctly. Sorry for this inconvenience.
                        • #184927
                          peteycorn
                            I’ll let you know.  It is supposed to arrive at Guitar Center – Sherman Oaks tomorrow
                          • #184936
                            peteycorn
                              Well.. I picked up the replacement Riptide from GC and immediately plugged it in and opened EDM.  There were again, only 5 presets.  The rest of the banks were empty.  There were again 2 firmware updates available, but when I attempted the first, I got the spinning wheel of frustration (then I thought to unregister the old Riptide and register the new Riptide.  When I was doing that I noticed that the serial numbers was only a difference of 2 (meaning that they were likely built at approximately the same and could be part of a bad batch)
                              One thing that we haven’t tried yet is updating the firmware from a file on my computer.  Is there a link to download the firmware updates directly to my drive, so I can try that? Or can you email me the files? And will I need to run both updates? Or do you have a better Idea/solution.. I can give you remote access to my computer if that helps (I’ve done this with Waves Tech Support) and maybe it can give needed info or there’s some way to diagnose the pedal from where you are……
                              This sux (but I’m confident that we can find a solution)
                              p
                            • #184945
                                Very sorry to hear you are still having issues.
                                It would be worth trying to update the firmware on your Blackhole pedal. I understand that your Blackhole is up to date, but this will help us determine if EDM updates are working on your computer. You can simply reinstall the latest firmware on the Blackhole pedal.
                                Please let me know what happens.
                              • #184946
                                peteycorn
                                  I re-downloaded and installed EDM, then ran EDM, chose the Blackhole, checked for updates, and ran the latest update.. Then I got the same results that I’ve been getting when trying to update the firmware of the two Riptides.
                                  Maybe my computer isn’t able to run the firmware updates :/  (see attached for results, and computer specs)
                                • #184949
                                    I’ve just emailed you directly and we can continue to troubleshoot the issue there. Thanks for your patience.
