Home › Forums › Products › Stompboxes › First Time with timeFactor!! some troubles
January 29, 2014 at 11:48 am #111351
Hi, all i'm having some troubles with my time factor, i wish you could help me, i'm using factor lib to organize my presets, but when i create a file and import my preset and click on send to timefactor, in the time factor display says "DONE" but my presets didn't updated, i have all the time the same presets!! :S any advice about what can i do,
and my second question is, is there any way to delete all preset saved?
thank you so much , and sorry about my english
greeting from spain
January 31, 2014 at 10:58 am #125330
no one can help me 🙁 ????????, i really need to know how to delete all saved presets
thank you so much
January 31, 2014 at 4:00 pm #125333
Restoring Factory Effects Presets and System Settings
CAUTION: This function will overwrite any Presets that you have saved.
To restore Factory Presets and all System settings, power up TimeFactor while simultaneously pressing the Middle Footswitch and the Encoder until [INITIALIZING] is displayed.
January 31, 2014 at 4:47 pm #136141
hi, i read the manual, but what i want is to delete all presets, not restore the 100 presets that comes with factory setting, i want 0 presets saved in the timefactor, and then starting to add my own presets
exist any combination to make that, i didn't find it in the manual???
thank you so much
January 31, 2014 at 4:54 pm #136142
Sorry but you can't do that. You can limit the range of presets however. So, let's say you only need ten. Limit the range to 10 and load in your own 10 presets. Then you'll never see any of the factory presets.
January 31, 2014 at 5:04 pm #136143
ohh thanks so much, I Skipped this step in my read of the manual :P,
thank you soooo much
