Fission not recognized by fl studio
Home Forums Products Plug-Ins Fission not recognized by fl studio
    • #114037
      fulvious
      Works well on ableton, but gets error in FL studio 64 bits. Using Windows 10.
    • #145846
      tlongabaugh
      Hi-
      What exact errors are you seeing? Is it crashing? Not showing up in the plug-in menu? Or something else?
      Best,
      Tom
      • #145850
        fulvious
        Fl studio scans fission and shows it like a plugin with error in the list. Unable to load.
        TLongabaugh wrote:
        Hi-
        Best,
        Tom
      • #145854
        tlongabaugh
        [/quote]
        Hi-
        I'm not able to reproduce here, it scans and loads fine. Can you try re-scanning your plug-ins in FL Studio's Plug-in Manager? Make sure "Rescan plugins with errorrs" is checked.
        Best,
        Tom
      • #145855
        fulvious
        Thanks Tom. Problem solved. I reinstalled fission checking both options, 32 and 64 bits and changed the directory. This is strange, becouse if I install only 64 bits, the plugin works well in others daws, but not in fl studio. I already purchased fission and I’m enjoying it
        cheers.
        TLongabaugh wrote:
        Hi-
        I’m not able to reproduce here, it scans and loads fine. Can you try re-scanning your plug-ins in FL Studio’s Plug-in Manager? Make sure “Rescan plugins with errorrs” is checked.
        Best,
        Tom
    • #145856
      tlongabaugh
      Hm, maybe FL Studio does some time of internal bridging from 32 to 64 bit. EIther way glad you have it working, enjoy!
