Fission – some thoughts.
Home Forums Products Plug-Ins Fission – some thoughts.
    • #114043
      Anatolyj_B
      Hi guys.
      Would be more interesting results if here would be ability to more divide of both contents (transient and “tonal”), ie in ideally we should have two faders, for maximum expression of each (both) contents (and process them through effects respectively).
      But current situation such, that middle position of “focus” fader make different from the original signal minimally, ie the difference of the separation does not significantly audible in this position. This makes sense only if we do not want significantly alter the original signal, but in this case the interesting idea decreases, and plugin approaching to just stack of two parallel effects.
      Ie need access to choice, for a more radical transformation.
    • #145869
      tlongabaugh
      Hi-
      Yes, it is true that we could add further parameters for the Structural Split section – the four current ones were chosen because they are relatively straightforward, but still provide lots of flexibility.
      I think you'll find you can get quite significantly modified sounds by solo-ing either the Transient or Tonal streams, or by using the gain controls on either stream, in conjunction with the split controls. You won't hear any difference from the main signal if you don't have any effects on, and the gain in Transient and Tonal is the same.
      Note that you can compare the difference of the split vs. just a simple mixer by using the On/Off button in the Structural Split section.
      -Tom
    • #145870
      Anatolyj_B
      Yes, about Solo (during fader lateral positions) its work, but need also division. (And two plugin instances into rack this is not good solution too, due to cpu usage this beast.)
      But thanks for available further improvements in advance.
      • #145886
        tlongabaugh
        I agree, two instances isn't an ideal solution. We have thought about different ways of allowing for external processing of the Transient/Tonal streams, and hope to implement something that allows this in the future.
