April 21, 2009 at 2:12 pm #106190
lionelred
ParticipantHi
I just unsuccessfully try to update my Eclipse from V3 to the latest OS
In the process I wiped my presets damn!
Nevermind I would still like to update as nothing to lose now.
I have a Mac and was using a flash card formatted on a pc FAT32
I now formatted on a mac just reads card not formatted?
any thoughts -
April 21, 2009 at 3:12 pm #118513
drooney
MemberHi Lionel,
When formatting a compact flash card for use with an Eventide product you will want to do so in the FAT format not FAT32. Mac's aren't able to format in this type so you can use the Eclipse to format your card.
Insert the card into the Eclipse and press 'setup' until you see "utility" and select it. Then select 'format'. You'll be asked if you really want to format it and select yes. It will only take a moment to format the card and it will indicate when this is complete. Once this is complete remove the card, and insert it into your card reader/writer and transfer the files for the 3.51 software. Follow the instructions provided for this method and you should be set.
Please note it is best to use a card that is below 2G capacity. If you continue to experience an issue feel free to contact support@eventide.com for further assistance.
April 21, 2009 at 5:07 pm #118514
lionelred
ParticipantJust tried that and the eclipse freaked a long bleep and then crashed.
I am using 1GB card so not sure really. -
April 21, 2009 at 5:09 pm #129664
drooney
MemberWhat is it that you tried? What do you mean by crashed? Does the unit power on normally?
April 21, 2009 at 5:20 pm #129665
lionelred
ParticipantSorry for not being clear
I did check the format type in the mac after formatting in the eclipse and it said FAT 32
I Formatted the card in the eclipse transfered the files from the mac (not in the folder though as it cant read the OS in the folder)
I boot up pressing 1 and it gets stuck on this message
loading romprog.exe from cardif it loads the display looks like snow storm of pixels, big bleep then powers down
April 21, 2009 at 5:38 pm #129666
drooney
MemberNo trouble at all. Well it sounds as though there may be an issue with the card you are using. I would try using a different card, preferably one that is a lower storage size than the one you are using.
April 22, 2009 at 9:03 pm #129672
lionelred
ParticipantHey
I tried it with a different card last night and it worked! thanks for helping me out, shame about my presets I'll just have to build some better onesmany thanks
April 24, 2009 at 1:47 pm #129674
drooney
MemberGreat news! Good luck with the new presets!
