Home › Forums › Products › Stompboxes › Flint Tremolo Settings for H90
- This topic has 5 replies, 4 voices, and was last updated 1 year, 9 months ago by
cjcampbell2000.
July 3, 2023 at 10:41 am #172260
hi all a question for those familier to a Strymon Flint.
I’m using a Flint for Tremolo the settings are
Toggle switch 63 tube
Intensity 4 o’clock
Speed 11-30 ish
It’s to copy and sound like my super reverb. So now id like to reproduce it on the h90
my setup is reverend rg-sus into h90 with ocd in loop out to the front of cornford hurricane
from what I’ve played with so far. I can’t seem to get close to the same intensity. so wondering about the best program to do this or if anyone has made and shared a patch even better thanks in advance
July 4, 2023 at 12:26 pm #172266
anyone
July 5, 2023 at 10:02 am #172283
When I’m doing country comping and Travis picking (for which American glass-based tremolo is the unofficial king), I use the TremoloPan algorithm. I recommend you start with type set to bias, drive set to 0, shape set to triangle, and mod source set to square. Set speed to taste, depth to around 60, depth mod to around 50, and mod rate to 1.000xSpeed. Increasing or decreasing the depth mod will add a bit of chop and throb to the sound, but it’s a balancing act between depth and depth mod to get it right for your sound. If you’re running in stereo, experiment with the Width knob as well – I usually keep mine around 0, bumping up occasionally to 15ish for just a little bit of movement.
Add some reverb (I like BlackHole, though Plate and ModEchoVerb can get you pretty far too) in front of the tremolo, and you’re off to the races.
July 6, 2023 at 4:00 am #172299
This works great!
July 6, 2023 at 12:49 pm #172307
Thanks man, this actually works!!!!! What a pedal!
July 12, 2023 at 9:03 am #172398
Heheheh. Soz I didn’t see your reply till now.
I’ve tried your settings and it’s fantastic, just a few alterations made it sound very close to my settings on the flint. so yippee Flint is coming off the board
thanks again amazeing
