FOH setting perfect but NOT dual mono…am I wrong
Home Forums Products Rackmount FOH setting perfect but NOT dual mono…am I wrong
    • #111306
      generalnoise
        Hi all.
        Just purchased the eclipse to use live with 2 vocalist at the same time in dual mono mode. Same effects just separate channels to send to the FOH desk.
        The "FrontOfHouse" setting, preset #462 is PERFECT but…
        Channel 1 is the echo
        Channel 2 is the verb
        I'm really trying to sort out how to route the effects so both inputs can be treating with the pitch, echo and verb.
        Is it a small thing I can't find or it is not possible?
        Or maybe I need to make a new setting by stealing the fx from this, either way that kinda blows by brain too
        Thank you
      • #125230
        generalnoise
          Ok….
          I went through the manual and made a new patch stealing the pitch effect twice from the FrontOfHouse preset once for each side, then panned the effect for each.
          I unfortunately loose the verb/ echo of effect 2 in the FrontOfHouse preset but have the pitch working independently in dual mono.
