Footsw Tip+Ring Causes Intermittent False Tip Signal
Home Forums Products Rackmount Footsw Tip+Ring Causes Intermittent False Tip Signal
    • #105705
      Viewed footsw config doc.
      3.5 don't know if same behavior in 3.1
      Config'ed footsw1 then tried footsw2, got same behavior.
      Prog- to tip, prog+ to ring, tempo to tip+ring.
      Tied tip and ring together and with 3A mom switched to sleeve.
      Sometimes can set tempo, many times get prog- instead.
      To work-around, I'll config with prog- on tip+ring.
      Will let you know.
    • #117610
      OK this work-around was successful;
      tip+ring set to prog-
      Switch tap tempo no longer causes prog change.
      Good to go.
