Footswitch and BPM
Home Forums Products Vsig and Preset Development Footswitch and BPM
Viewing 7 reply threads
    • #107564
      Two questions:
      – What is the easiest way to incorporate a footswitch into a VSIG program?
      – Is there an easy way to get the delay time parameter (of the delay module) to be displayed in BPM ?
      Thanks
    • #121411
        One – use an EXTCONTROL module
        Two – use a C_DIVIDE module to divide 60 by the delay time – this will give an output in BPM
      • #121414
        Excellent. 🙂
        I had to use one C_Divide (in1=60 and in2= knob) and one C_multiply (in1=1000 and in2=from C_divide out) to do get the parameterdisplay in BPM.
        Do the have to be Extcontrol initialized at each loading or is there a way to preset it in Vsig (to e.g. ring1 )?
        What is the difference in use between the EXTCONTROL and the EXTTRIG module?
      • #132598
          You can init the EXTCONTROL in Vsig but it's not worth the effort – if you set it up in the program on the machine, it will remember. If you want, you could then get the file back into Vsig and look at the numbers.
          EXTTRIG generates a trigger – a signal that goes high briefly and then goes low.
        • #132600
          Thanks. Which modules would would you use to construct a simple knob-controlled feedback for the delaymodule?
          I ended up using a Knob, a C-to-A module, an Audio Multiply and an Audio Adder, i.e. 4 modules…
        • #132603
          Found out I can probably use a Mixer module and a Knob – half the number of modules 🙂
        • #132610
          Is there a way to transmit the name of a preset from VSIG to the Eventide unit?
        • #132611
            Used Edit/Set Title and Author
