September 30, 2009 at 1:48 pm #106484
romadream
ParticipantHi Italo…..I want ask you how can i backup my Eclipse presets on a compactflash card……and how can i copy them back to the Eclipse, after 4.0 upgrade?
Thanx a lot!
Ps.se sei italiano scrivi pure in italiano che per me è meglio…grazie mille! 🙂
September 30, 2009 at 2:08 pm #119131
IDeangelis
MemberHello
check under SETUP > UTILITY > COPY
SOURCE FROM/SOURCE TO set the range of presets you want to copy (from #…to #).
DEST FROM sets where you want to start copying the presets.
Card presets are numbered from #500 up.
best
I
October 9, 2009 at 11:04 pm #119214
dannyagogo
Memberi tried this with my eclipse it downloads to card(had to wait awile).checked on computer and had a PGM folder but couldnt open it and when it was put back into the eclipse from 500-598 where i saved the presets were empty.
October 12, 2009 at 8:56 am #130357
IDeangelis
MemberI don't know which presets *NUMBERS* you are trying to back up.
Maybe you are backing up factory presets?
From the V4.0 Release Notes:
If you use BLOCK COPY, do NOT try to backup factory presets at the same time
If BLOCK COPY is used on factory presets, the resulting saved files will be
corrupted.Have you followed the Release Notes indications for a correct OS installation? A CLEAR SETUP is a must.
best
I
October 13, 2009 at 4:42 pm #130377
tomoe97
ParticipantI performed "clear setup" when upgrading from 3.51 to 4.0 Beta, but not between 4.0 Beta and 4.01–is this a problem? Everything seems to be functioning properly. Is it possible to "clear setup" after the fact?
October 13, 2009 at 4:47 pm #130378
IDeangelis
MemberNot reallya requirement as the system didn't prompt you at latest release version.
Nevertheless i prefer to always do a CLEAR SETUP, provided my presets have been backed up before.
You can CLEAR SETUP at any time by powering the unit on while pressing & holding the SETUP key.
best
I
