ganged parameters
Home Forums Products Rackmount ganged parameters
    • #113572
      HI,
      i would like to know how to gange parameters on the h8000.
      found only how to un-gange in the manual but not how to gange them.
      also want to know how to do a factory reset of all parameters.
      Thank you,
      Brian.
    • #143844
        To gang preset parameters, you have to edit the preset using a tool such as Vsig (not for dilletantes).  Look at the info on the GANG module.
        Gangs cannot be added to system parameters.
        For a factory reset on parameters:
        a) Preset parameters are reset to default values on loading the preset.
        b) Syetem paramters can be set to factory defaults as described in the User Manual.
