Generate ADSR – Issue
Home › Forums › Products › Plug-Ins › Generate ADSR – Issue
Viewing 6 reply threads
    • #162986
      babacane
        I’m using Generate and loving it. Recently, when pressing a note,  I realized there was still a sound ongoing (quite low) even with sustain at 0. The same is true with the  realease, you can hear a sound after realeasing a note for approx 1 s even with realease at minimum (1 ms). The strange thing is that I never realized this before! My expectation is to have no sound at all in both cases. Is that something normal? any turnaround?
        Thanks in advance!
        Ciao
        Daniele
      • #162989
        babacane
          Just to add some other element.
          I’m on PC recently ipdated on W11 and using Reaper. Actually I’m pretty sure this was not present earlier. In effect, as it is now, you cannot have dry or snappy sounds…
          Thanks in advance
          Ciao
          Daniele
        • #162990
          DGillespie
            Hey, I’ll have to look into this. Does this happen in both Vactrol mode on and off?
            Thanks,
            Dan
          • #162993
            babacane
              Hi Dan,
              Thanks for your reply!
              I have checked. It happens only with vactrol mode off.
              Ciao
              Daniel
            • #163511
              babacane
                Hi Dan,
                Any update regarding the ADSR issue? I can understand this is not a priority but I would love having a feedback.
                Ciao
                Daniele
              • #163561
                DGillespie
                  I’m sorry, Daniele, but I have not yet had a chance to look at this.  It is on my mind and I hope to get to it soon.
                  Sorry,
                  Dan
                • #163564
                  babacane
                    Thanks a lot for your reply!
                    Generate is such an unique VST synth!
