Generator midi learn ?
Home Forums Products Plug-Ins Generator midi learn ?
Viewing 4 reply threads
    • #116115
      egodzillav
        i’m concerned.. i can’t find midi learn anywhere. am i missing something ?
        frown
      • #155899
        DGillespie
          This is something we’re working on presently.
        • #155905
          egodzillav
            Ok thanks.
            Also.. i just can’t use that plug with my i7 2600k 32Gb. it’s killing my cpu unless i use only this.
            any chance you are working on optimising the consumption?
            I ask because i know u-He plugins like Diva had something like that when they came out.
          • #155909
            DGillespie
              Can you try turning OpenGL off and turning visualizations off (you'll need to close and open the UI after turning OpenGL off)?  Does this solve your CPU problem?  I have a similar machine and the default patch uses about 20% of one core.  I would expect the same for you, but sometimes the UI animations or OpenGL can cause CPU problems on some peoples computers.
              Dan
            • #155911
              egodzillav
                HI,
                Thanks for the idea. i don’t see a massive improve if any.
                here my cpu looks like 25% then i hit a key it jumps 75% :p or overload on some presets.
                i tried to remove fx but doesn’t change.
                i’ll try with a session that is very small but.. pff i don’t see using this plug in pro context. i need video, orchestra.. lots of stuff.. limiters etc. and until i have a nasa computer i prefer not to use a plug is that much heavy.
