Home › Forums › Products › Stompboxes › Getting an H9 core aside my H9 MAX
- This topic has 4 replies, 3 voices, and was last updated 4 years, 7 months ago by
habe.
February 10, 2022 at 6:56 pm #162132
Hello, sorry if this question has been asked already. I own an H9 Max, and I wonder if I can get a second hand H9 Core will it share the same algos of the Max? Or should I instead upgrade the Core to Max ?
Thanks
Paul
February 10, 2022 at 7:05 pm #162133
If you have a H9 Max registered with Eventide and add an H9 Core and register it, you can sync the algorithms on the Max to the Core. No need to get a second Max, as long as they are registered to the same Eventide account.
February 10, 2022 at 7:20 pm #162134
That’s great thanks. Yes I have both my H9 Max and my Micropitch Delay registered to my own account.
February 20, 2022 at 6:51 pm #162324
Good evening,
I have a H9 max and bought a core a while ago. Both are registered on the same account. I use H9 Control 4.0.3 for IOS and I can connect both H9 to H9 Control on my iPad pro via Bluetooth.
However, the Core does not get access to the Max’ algos. I tried “Restore purchase” but it did not work as the Core remained Core. On the app (“Preset Lists”) I tried to access source (=iPad) but there it does no show any source and therefore I could not copy the max algos via “save to ipad” (which does not show up either) from the Max to Core. I checked the forum but I could not find an answer to this issue. What could be the remedy? Grateful for any suggestions. Thanks in advance.
February 21, 2022 at 10:55 am #162327
Please note that I could meanwhile solve my issue raised in the previous message. I deleted H9 Control from the iPad, re-installed it and linked it to my Eventide account again. That sorted out the missing “source” symbol as the iPad symbol appeared in the app. As explained in other threads, I saved the preset list of the MAX to the iPad. – Interestingly, H9 Control did not connect with the Core at first. After numerous attempts to connect and maybe because I finally disconnected the Core from the mains for a moment it worked in the end. I saved the MAX preset list from the iPad to the Core. Now the 2 H9 have the same presets. In hindsight, it was straightforward.))
