Gig Rig Generator
Home Forums Products Stompboxes Gig Rig Generator
Viewing 6 reply threads
    • #106061
      Does anyone know if the Generator could power a Timefactor and a Modfactor?
    • #119423
      Hey http://www.thegigrig.com/acatalog/ scroll down and there is an adapter so you can run factor series pedals off of generator..
    • #119426
      thom
        I have been using the Gigrig Timefactor adaptor for a while now with a PSU that gives 1.6 amps  at 9 volts. This also powers a booster pedal, distortion pedal, a lovely Wampler Ego compressor and a rarely used Boss Enhancer pedal. The Gigrig Timefactor adaptor allows me to run the Timefactor in the daisy chain and eliminates the enourmous wall wart. It works perfectly, fit and forget as these things should be.
      • #131474
        Hello there,
        Maybe our brand new CIOKS DC10 is something you should consider… Please let me know exactly what you have on your pedal board and I will come up with a solution for you with exact figures on voltage, current draw and plug types you'd need to power it all properly.
        Regards,
        Poul Ciok
        poul.ciok@cioks.com
      • #131478
        And does anyone know if you can power two Factors off one GigRig Evenflo adaptor?. The Generator is rated at 5000mA so the source is powerful enough. Its rather a dear do to buy one for each.
      • #131583
        I just had the Gigrig answer, and yes you need one adapter per pedal as each should be isolated.
      • #131606
        I just use a PRIME power strip
