Home › Forums › Products › Stompboxes › Gigrig G2 and H9
- This topic has 7 replies, 2 voices, and was last updated 2 years, 8 months ago by
Eventide Staff.
October 2, 2015 at 5:12 am #112907
Putting together my Gigrig system and everything works except the H9… It seems to interact with the volume pedal and the post gain level.
The effects sound phasey and they oscillate into feedback on some of the presets.. What can it be??
October 2, 2015 at 2:06 pm #140826
The Gigrig is such a complicated thing it's hard to say. There are plenty of people though using that with the H9 without any problems. So, there's no fundamental problem with using the two together. I don't know a lot about that product. Does it allow you to keep a separate dry path and mix that with a signal going through a stompbox? That would result in a phasey sounding signal… Generally speaking with feedback, you'd want to check whether you've actually set up a feedback loop, no?
October 2, 2015 at 2:18 pm #140827
I’ve been using G2 and two H9 for a while. Works flawless. One H9 I use both pre and post routing.
I’ve just set them up like any other stompbox.
October 4, 2015 at 5:29 pm #140851kingston wrote:I’ve been using G2 and two H9 for a while. Works flawless. One H9 I use both pre and post routing.
stompbox.Do you have a volume pedal in the insert?
October 5, 2015 at 3:43 pm #140874tenohr wrote:kingston wrote:I’ve been using G2 and two H9 for a while. Works flawless. One H9 I use both pre and post routing.
No, but I have been using the insert for fx loop, and now I now use for the dry signal in a wet/dry setup.
October 2, 2015 at 2:33 pm #140829
Guess I´ll try to reinstall the firmware and see what happens..
January 27, 2023 at 5:33 pm #168701
I’ve tried searching this forum for my issue but your forum keeps timing out.
My H9 keeps crashing with the GigRig Evenflo but works fine with the Eventide power supply.
I have the same issue with 2 seperate Evenflo devices.
I know the Evenflo works for many but not for me.
Is it my H9?
January 30, 2023 at 10:21 am #168734
Sorry, we can only officially recommend using the included power supply for your stompbox, or an Eventide PowerMax/PowerMini.
If your H9 is working correctly with the included power supply, it is not likely that there is an issue with it.
The H9 needs a 9V DC 500mA, Center positive power supply.
