- This topic has 7 replies, 3 voices, and was last updated 6 days, 6 hours ago by
pportellano.
April 11, 2024 at 6:11 am #180879
Hi all,
I’ve just released the Pitchy Granulator MIDI algorithm, which brings granular synthesis to the H9000 for the first time.
This algorithm takes grains from real time audio input and uses the MIDI note, to replay the grains at the selected pitch. The algorithm features a freeze function, grain window manipulation and can independently repitch the left and right signals.
It comes with 9 Presets.
You can see a demo at: https://youtu.be/aV2qe8M3Nx4
The algorithm, manual and presets are included the package available from https://www.buymeacoffee.com/godlikeprod/e/242326
This algorithm is available for free to my BuyMeACoffee subscribers.
Please be sure to read the manual, as this is quite a complex little beasty.
The block diagram with available controls is below.
April 19, 2024 at 3:54 pm #181146
Amazing! I have so little time at the moment to work on my sounds (at least I gig a lot). I don’t think I’ve even opened Vsig in 2024…
I’m going to have a deep-dive in the H9000 very soon.
Keep up the good job, Puppeter!
October 18, 2025 at 6:35 pm #192673
Excuse me for my probable ignorance. This algoritm doesn’t work on Eventide H90, right? Is that something that you could maybe adapt?
Thanks.
Pedro.
October 18, 2025 at 10:51 pm #192676
Hi, Excuse me for my probable ignorance. This algoritm doesn’t work on Eventide H90, right? Is that something that you could maybe adapt? Thanks. Pedro.
Unfortunately no. The H90 doesn’t support VSIG and I don’t have a H90 in any case as an export destination for any custom algorithm, or preset development.
If the situation changes and I can target the H90, I will, of course, strive to support it as much as I can.
October 19, 2025 at 3:24 am #192677
Ok, thanks for the information. I didn’t know what VSIG is, so I checked online, and found this definition:
“VSig is a Visual Editor for producing user presets for the Eventide ORVILLE, DSP7000/4000, and current H-Series Processors”
H90 is not part of the H-Series Processors?
October 19, 2025 at 3:32 am #192678
That’s not a great definition actually.
VSIG is a visual programming language to create ALGORITHMS for the Hx000 series.
Presets are build on the unit itself and are basically saving parameters, or knob positions of an algorithm.
I don’t know whether its even technically possible for the H90 to interface with VSIG. That’s definitely Eventide territory.
October 19, 2025 at 4:03 am #192679
I’ve just came into VSIG again after a two-year break (H9000 upgrade effect, lol). If VSIG could interface with the H90 through the H9000, that would be amazing! Honestly, I think Eventide should do more to support third-party algorithm creation: make it easier to use, share, and transfer them between units. That would really boost the whole H-series .
October 21, 2025 at 12:53 pm #192755
Hi, I have just received a reply from Eventide support, and @puppeteer you were right, they told me this: “The H90 does not support the VSig format for algorithm creation”.
Thanks anyway.
