July 11, 2009 at 11:52 am #106305
ackcl
MemberHi all
I have already used the XLR to 1/4 cable method, however I found that there are significant tone changes when I use the eclipse in the effect loop of my Boogie and Suhr amps. It sounds like there is a filter with some frequency missing. I have tried several patches (e.g. Reverb8, Delay8Plex, LrgDelay8Plex, etc.), the problem still exists. There is no such problem with other delay pedals. Is there any wrong with my setting? Any suggestion?
P.S. The global mix is about 40%, input and ouput gain are set to 0db.
Thanks
Lester
July 11, 2009 at 11:33 pm #118784
simeon
Participantchange the global mix to 100% and make sure the fx loop on the amp is set to 100% wet also and see if it's any better. sounds like you're hearing a mix of the dry signal going around the loop and the dry signal passing through the eclipse
July 13, 2009 at 3:40 am #118789
ackcl
MemberThanks. I will try it out!
Cheers
Lester
July 13, 2009 at 8:12 am #129905
IDeangelis
MemberIf your amp(s) FX LOOP(s) are parallel type (check their manuals/support) then wet/dry mix on fx processors should always be set to 100% wet, otherwise you get two instances of dry sound that get "comb filtered", giving the tonal changes you report. On a serial FX LOOP you can set dry/wet as you like.
I
July 13, 2009 at 3:07 pm #129910
ackcl
MemberHi Italo
I know that the effect loops are serial one.
Can I obtain a better result with higher sampling rate on the Eclipse? Thanks
Lester
July 13, 2009 at 3:26 pm #129911
IDeangelis
MemberHi Jacob
then you can use wet/dry mix as you like as there is no dry passing thru the loop (serial FX loop).
Sampling rates higher than 48KHz would not really do much better to a guitar played thru a gtr amp. Its speakers are bandwidth limited anyway. Filters and verbs, particularly loooong ones, benefit from higher sampling rates. A good thing to try out in a studio recording.
cheers
I
July 15, 2009 at 10:42 am #129918
ackcl
MemberHi all
Just found that the issue is due to using a minimix from suhr which makes the serial loop becoming parallel. All problem is solved now. Thank you guys.
Cheers
Lester
