Home › Forums › Products › Stompboxes › Guitar Wing controlling the H9
July 14, 2014 at 9:32 pm #111788
jekblad_livid
MemberI've been working with the H9 and the Guitar Wing these last couple days… lots of fun. However I can't seem to get the "on" command right. I can change patches, but which midi command actually turns the new effect on? I assumed it would function like the actual switch does on the hardware, do I need two different commands?
July 14, 2014 at 10:18 pm #126337
pauliusmm
MemberHow do you connect these? Do you need a laptop for them to work?
July 14, 2014 at 10:19 pm #126338
Hard to tell without knowing what commands you are using.
If you are sending MIDI Program Change, and the preset was saved in Active (i.e not bypassed), that should be enough.
July 14, 2014 at 11:11 pm #126340
jekblad_livid
MemberI see. I was only sending CC's, looking for some sort of toggle behavior
July 14, 2014 at 11:12 pm #126341
jekblad_livid
Memberyou can use a USB midi host from kenton or iConnectivity.
July 14, 2014 at 11:20 pm #137021
gkellum
ParticipantYou can assign a MIDI CC to toggle between active and bypassed. If you look in H9 Control under Pedal settings (click the Pedal button in the bottom right hand corner of the screen), go to Midi Settings, and go to "Assign MIDI CC messages to Pedal Functions", you'll see a Pedal Function labeled "Left Footswitch (aka Active Footswitch)". If you assign that pedal function to a MIDI CC it will toggle the current preset between active and bypassed every time it receives a CC value above 64…
July 14, 2014 at 11:26 pm #137022
jekblad_livid
Memberthat seems like exactly what i was looking for. Thanks for the helping hand!
October 7, 2015 at 1:57 pm #140906
rdnzl
ParticipantHello there,
I was wondering if the guitar wing can communicate with the H9?
Can we acheive 2 ways communications as well (where the H9 would send info to light up or shut lights off on the guitar wing upon changing patches).
http://wiki.lividinstruments.com/wiki/Bluetooth_LE_MIDI_Connection
Cheers
October 9, 2015 at 7:57 pm #140969
Alancarl
ParticipantHi H9 GW people,
I was just setting up the scenario where my H9 is being remote controlled by my Gtr Wing.
The setup includes the H9 control app on my iPad with Blietooth MIDI LE running on the iPad.
Afaik the H9 pedal needs an iOS device or a computer to serve as the Bluetooth MIDI host and the pedal and the Gtr Wing are clients.
Hope this helps… Google searching is a must for my success!
Thanks
Al
